Can a pressure test be performed on an Alpha 1 Gen II while it’s still on the boat
Rick Stephens
Merc engineers were *brilliant* when they did away with the spring loaded method and went with a fixed lash. Needs more tools to set up properly but is mechanically much more reliable.
Skidude17
I’ve got the 2 halves back together. I put 10 psi of pressure on the drive last night. After 10 minutes and with spinning prop shaft and changing gears no change. After 12 hours I had 5 psi. I’ve checked through the exhaust opening with soapy water, and where the oil path goes between the drives. Where else should I be looking?
alldodge
There might not be a problem, temps change at night. Could also be the gauge and/or fittings used may have the leak. That said I've never let one sit all night, after an hour I'm good and fill it back up.
How did the vacuum check out?
Rick Stephens
Agree. Hour or two, golden.
Skidude17
I’m doing the vacuum right now. I was waiting to figure out the pressure test first.
achris
More fish than mountain goat
Pressure and vacuum test only need to be held for 15 minutes. Any longer than an hour and you're going to get 'false failures'...Like you have.
Chris.....
Skidude17
Chris.....
Good to know. Thanks for all the help everybody! I’ll be filling the drive and putting it back on tonight.
