can anyone tell me?
1975oday22
what this tan wire is for? im guessing maybe water pressure or temp? does not goto my dash, only tan wire is comming off my controll box accessory plug wich has a bullet connector
Chris1956
Very likely that is the overheat switch. it will connect to ground when it detects motor overheat. You will want to connect it to the negative side of a horn or buzzer. Most newer controls have those built in.
