Re: Can I put U-Bolts here for Skiing and Tubing ?
As someone who has the IDENTICAL boat and identical pylon to the link posted way above, I can tell you from 12 years of owning that boat, that not once did I have an issue with a tube being pulled on it. Had tubes flip over, had ropes break, but yet the fiberglass and pylon held without so much as even a crack in the gelcoat. The only issue is that the boat would end up at an uncomfortably steep angle if you get a tube that bogged down inside a turn.
Honestly if the pylon isn't strong enough for tubing, there is no way I'd want to ski behind it either. A strong experienced slalom skier can put almost as much pull on the line as a flipped tube.
