Realgun
- Jul 31, 2003
- 2,484
Re: Can I skip the stringer epoxy soaking? Can I use resin instead?
Basically its thickened epoxy. You add fibers for strength or microballons for filler.<br /><br />What your doing is making a putty to fill in gaps. if you need to fix say a floor edge to a hull you use fibers. 1/8" or 1/4" the longer the better but the longer the stronger also more rough the stuff is. If you filling a gouge in the hull, cosmetic, then you use microballons and little fiber.<br /><br />The putty can be made so thick you can hardly spread it or like "peanut butter" hence the name.<br />If it too thin the epoxy or poly will run away from the fibers.What's this peanut butter yall speak of?
