NormRinker
- May 7, 2007
- 56
Hey all,
Can I substitute my original '98 5.7L MerCruiser/GM 5.7L engine with hydraulic roller camshaft and lifters for one with the hydraulic flat tappet camshaft and lifters set up? It will still be of the '87 or newer variety with the one piece rear main seal. I suppose that's where it was different on the crankshaft rear bolt flange between pre '87 and post '87 designs. I want to stay with the newer one for my flywheel, starter, etc to bolt on if that's all direct bolt-on stuff I am thinking here. There are several nice crate flat tappet engines that I like, and some of them use Vortec cylinder heads. Besides the newer Vortec heads and intake manifold, What differences are there if any that I need to look out for going with a '87-'97 block in place of '98?
I can take care of the engine's top end as I will be staying with the Vortec stuff. I was more wondering if going with a hydraulic flat tappet camshaft and lifters won't affect anything with the Thunderbolt ignition system that's on there. I would think the engine wouldn't know what is what that's in there as long as the camshaft profiles and specifications doesn't differ too much.
I'm looking forward to seeing some of your replies on here. Blueprint Engines make some nice marine long blocks, crate engines, and there are some nice flat tappet GM Performance engines as well that might be marinizable. The cost difference between two type of valvetrain set-up is of a pretty good margin. I know most will say to stay with the roller lifters, but can a well thought out flat tappet engine work just as good in terms of moving the boat around with some power without affecting anything?
Thanks
Thanks
