biglurr54
- Feb 14, 2011
- 234
Last night I went to switch over to my built in tank on the boat. The inline valve I have that is used to prevent the fuel from coming out of the built in tank when not in use was stuck. I worked it a little and it broke free. Well the spline broke free from the valve so it is stuck in the off position. Today I went out to get a new valve and all the local stores only had three way valves. I only need a shut off valve. I went to HD and in the plumbing section they had a 3/8's threaded brass valve. Its says it can be used for water, oil, or air. Can I use this valve until I can get my hands on a proper valve? Will i need to get my hands on a proper valve or will that one be fine?
