jrttoday
- Feb 8, 2010
- 1,081
wish me luck!!! This isn't stacking up to be easy, but am feeling confident about it working out. Confident about cussin, fussin, and getting a bigger hammer too LOL.
1st of all, putting the bolts in will have to be done as, or before she goes together. Lots of trial and error to see what has to go when? I'll let ya know just in case someone else is kwazy enough to try!!
http://
It's just sitting in there for now - except for two bolts top of the brackets, finger tight, and not even SS. Figure out in the morning where and how much to trim back on the brackets; they won't be directly load bearing like they would on for standard use. BUT!!! they will be subjected to some force??? and WILL have the standard 4 bolts holding them on.
Took the flat bar bracing, top and bottom, off - (8) 1/2x1" SS bolts and 8 roll pins total. Back and forth, WD40..... broke two bolts anyway. Not going to use heat against the boat; ground them off flush because I'm not going back with 'em. Maybe on top cos I have room on the forward side, but to t/t and brackets "should" tie it all in.
Back of the CMC will be scabbed over with landings for trim rods; not certain as to exactly how to do that yet? Possibly salvage yard has some? or I'll make something.... as usual LOL
http://
