jrttoday
- Feb 8, 2010
- 1,081
a good washing and wax will have to wait... just rinsed it off. This should be about "how she'll sit on plane".
Cavitation plate is "close" to parallel with the hull; no need to bother with exact for now. Ruff measurement was 4" above; which only testing will tell if too high - 3" before wasn't enough with the offset being 6". It's now 10" offset which throws the weight of the motor back some - changes things!!! More is not always better; even on a performance hull, you can go too far.
Had to open up the hole for steering cable - no big deal
Have a can of paint coming to touch up spots, but wondering why the "thing" turned out lighter - supposed to have been the same color. Used gray primer on it and not the motor, hmmmm....
Still have the emblems to paint/install - that's what those holes are.
She was fast enough before and wasn't really looking to tweak that!! Trim needs to work, period. Maybe there was something defective with the CMC I had? but it was no match for the torque of this V4; in four years, it wasn't enough for my other motor either.
The release valve only needed an O-ring; I couldn't believe it gave me so much trouble. Could hardly see where it had flattened out, letting it suck air.
PS: I was shooting for 8" offset!!! BUT!!! it just turned out to be ten.... It "appeared" that it couldn't be made any shorter with "what and how" I was having to make the thing. I DID NOT want it out that far, but oh well.... we'll see....
IF!! it still floats :lol:..... I'll run this until I get tired of messing with it, lol.
