Can Someone Please Explain The Alpha Gimble Oiling System To Me?
nowwhat!
Re: Can Someone Please Explain The Alpha Gimble Oiling System To Me?
I still don't understand how outboards are cheaper. You just throw out the old and put on a new one. That would get expensive. The problem you are facing is that you have an I/O that someone messed up. If it was still a Volvo setup it would be easy to fix.
Very true, If you are buying new, I could/would never buy a new outboard. There are always deals to be found on used outboards.
81 Checkmate
Go to sterndrives.com and look up your original drive serial number............
Could not find an OC582279.........Found OD582279 Alpha 1 Gen 11
That could be your difference........Ive learned over the years...... do alota research before taking apart or slapping things together
The net is your best friend......:rolleyes:
Good luck!
I consider myself fairly handy, i have owned, outfitted, and maintained several boats in the last 20 years without the intervention of a mechanic.
My failing here is definately a lack of knowledge of mercruisers, i/o's and grossly underestimating the cost to fill in the gaps. I guess there's a reason so many people convert and put an outboard on.
Ayuh,.... I've seen 6 attempts so far, 'n None were successful....
I'd still like to see this question answered though....
I just can't see where yer headed... Where's the goalposts in this contest,..??
What are you tryin' to marry to what, to get Boatin',..??
