Can the base of engine work? Two to bolts under engine are rusted and can
Scott06
Should I do any maintain for the sealed bearing. I tried to turn it by my hand and felt it is not very smoothy while turning
there is nothing to maintain on the sealed bearing - only to make sure water stays out . If it is not smooth then replace it
liusigou
is my gimbal bearing in the good working condition? the below is leaking. and I have to reseal it. Maybe the leaking into water led to the damage the sealed gimbal bearing.
Scott06
If you had leaking bellows yes replace the gimbal bearing while you are in there
They do not like water
Grub54891
Those bearings are not true sealed bearings. A true sealed bearing has a rubber lip on the inner race area. They are shielded bearings, unfortunately they can get water in them from leaking bellows. If everything is fine with the bellows, they last a long time. As long as alignment is good they are fine. Heck, my bellows are 10 years old and so is the bearing.
liusigou
Then you are doing something wrong. Bellows should last years
I know the bellow is good. only it is leaking. So sometime I do not like to raise the outdrive too high. and Now I get more familiar with reseaing. Also I found that it is dirty beside the lower shift cable. See attached file at No. 300. What happened? Yesterday I just ignored this issue
tank1949
Anyone can help me check again this gimbal bearing had hole or not? At that time I could not find a hole for grease filling, now I tried to fill the grease. and attached file is what I saw. You can click the link to see the detail of the gimbal bearing I bought 2 years ago. Maybe I have to pull it out and check it again to ensure I install the gimbal bearing correctly.
some ODs don't have grease holes and use a sealed bearing.
liusigou
Today I run my motor at my driveway after one day in the lake and I heard that there some click noise from outdrive then I took the outdrive off and found some white water flew away from lower shift cable. also I upload all the pictures of my gimbal bearing house. Do you know where is the water from ? I resealed the bellows a week ago. Is it possible that water leaks from lower shift cable?
liusigou
Water can be seen in the slide block house. What is the reason cause the leaking water? Is it possible the nut of lower shift cable loosen?
JASinIL2006
Could be a hole in the bellows or a bad seal of the bellows to the places it attaches to the boat. Could be a bad transom gasket or one that was improperly installed.
I'd be checking the bellows.
liusigou
It seem the nut of the low shift cable was loosen and It did not leak one day in the lake after I made it tight
liusigou
Yesterday I went fishing and it run good about 30miles at the beginning, but 8 hours later it run very slow wit the speed not more than 10 miles and I have noticed the engine is a little bit hot. and I did run at my driveway when I got home. You can see my running video at following link. Can anyone help me identify the issue.?
there is not any leaking water into my boat any more.
Grub54891
Do you have the big square o-ring in the housing? All I see is grease and water.
liusigou
Yes. I have fixed this issue and there is not any water in the u-joint bellow any more. It is very clean. I have just taken a photo inside the bellow
Grub54891
Hope it stays dry. I have to ask again if the o-ring was in place or what you did to fix the issue.
liusigou
Before the o-ling was missing and water leak into boat. But the o-ling has been put back and there is not any water in the u-joint below. My boat slow down after some hours in the water
Grub54891
Glad you got the thing figured out. Hopefully others chime in and get yo running better.
