I've been playing around with a light plywood runabout design for a while, but I've been stuck on a regulation. If the deadrise is less than 5°, you follow one equation for maximum recomended horsepower, and if you exceed 5°, you follow another. Since the 'less than 5°' equation doesn't account for remote steering, there's a large difference. Maximum goes from 20hp to 40hp on my virtual runabout. It needs to be 28hp
<br /><br />Here's how they put it:<br />
My questions are:<br />1) I've found 'Midships' mentioned in the regs as being a section precisely halfway between the tip of the bow and the top lip of the cutout. What is the significance of deadrise here? I thought it was only important on the running surface? Currently my bottom only has 3° here, but I could increase it easily enough.<br /><br />2) Do you think the '(No Flat bottom Boats)' basically rules out what I'm implying to do in 1)? I mean, it's flat at the back afterall.<br /><br />3) Say I change the bottom from flat to 5° all the way along until the back. How will that alter the ride? Will it slow me right down?<br /><br />Unfortunetly, there's no consideration for anti-trip chines and the like. Of course, this is a protected waters boat.<br /><br />I'd really appreciate hearing your opinions. I can post the lines if you want.Midship deadrise angle greater than 5º, (No Flat bottom Boats), ...
