kawliga129
- Aug 23, 2007
- 5
I have a 1989 Bayliner Capri 1950 with a 3.0 liter I/O. My throttle control is labelled "U.S. Marine". When pulled "out" into neutral it will work forward and backward just fine, and it also throttles the engine in both directions fine as well. When pushed back "in" to engage the propeller it will not even allow me to pull it back into reverse but it will go forward and spin the prop forward. Also, the lower half of the neutral safety switch is snapped off at the screw and does nothing. Any ideas? I've read a few posts and it sounds like the lower cable may need to be replaced, but if that was true it shouldn't go forward correct? Any suggestions please?
