Re: cant get lower unit to come off johnson 175
remove your starter and probably your starter solenoid to remove the starter. This way you can see under the bottom carb. Sometimes you might have to remove the bottom carb. It depends on what kind of motor skills you have with your hands. Good luck it is not hard to get to that bolt holding the shift rod.
