I have been changing props and now I can't get the alum.prop with the rubber hub to snug up it is loose enough to rattle. The S.S.prop with the fixed hub snugs up fine. The stress washer looks ok , the washer behind the nut looks like it is warped out a little. Can I put a thicker washer behind the nut or have I damaged the rubber hub?
