I'm going to need some help on this. I'm winterizing my boat today, oil change went well, installed new oil and filter, I went to remove the flame arrestor as I wanted to 1) fog the engine, 2) I need to clean the flame arrestor as it's dirty.
Last year (1st year I owned this boat) the flame arrestor came off just fine. This year this spring I had a transom kit installed, engine alignment, etc. Well, they must have had to raise the engine quite a bit to align it because now there isn't enough clearance to remove the flame arrestor. The carb is a Weber 4-barrel, there are two metal things that stick up on each side, just to the side of the venturies, they area about 3/16" too tall. Each one is held in place by a small screw.
I'm wondering A) what are these things? B) Can I simply remove the small screw, remove the metal thing and trim them down a bit? And also remove the flame arrestor?
Any help will be greatly appreciated!
I'll try to post a couple pictures, hope it works.
Having trouble uploading pictures, the file is too big and my phone camera is already at it's lowest setting, , or whatever you call it
