Capacity
donzi15
My boat has no capacity label posted inside of it anywhere, I have searched on line and came up with nothing so I'm reaching out on here. I did use the "capacity calculator" but I'm not sold on the answer(11people-1600lbs). It's a 1989 Donzi 21' cuddy with a 5.7/OMC.
blackhawk180
Re: Capacity
I'm not sold on that answer either, donz. Besides the obvious "where would everyone sit", I'm pretty sure that would exceed the actual capacity plate for number of passengers. I googled a bit but didn't find anything specific to your boat but you are in the right place to find the answer. I would want to know the specifics before I headed out.
donzi15
Re: Capacity
I've been out 4 or 5 times Blackhawk and I'm pretty positive 6 people is not a problem, considering 2 captains chairs and the bench seat comfortably sitting 4 medium adults. This weekend however I'm taking the fam out(niece, nephews and sisters) total of 7 with me. So now im worried, I dont want any problems with the law!haha
Dawg'sLife93
Re: Capacity
I looked at a 23ft Donzi, when I was looking for a boat. It was close to my Cobalt which is 6 people and 1100 lbs 1300 lbs with gear.
rallyart
Re: Capacity
There is no requirement for a capacity sticker on a boat over 20', therefore in is not a risk of a problem with the law for not having one. If you don't have one you are not over the listed capacity. The regulations expect that when in a larger boat the pilot will have knowledge of what is best.
In any case, having eight people in a 21' boat is not likely to be over the capacity of the hull to carry, even on a narrow hull like a Donzi The number of seats is not related to the capacity of a boat to carry people or weight.
donzi15
Re: Capacity
Thank you Rally!! That is the exact answer I was looking for. I've been around/on boats for around 15 years but just now decided to purchase one. Actually owning/operating your own vessel makes you a little more aware and cautious of procedures and laws. So in other words on a boat over 20' its the discretion of the owner/operator to maintain a safe weight and/or passenger count while operating. Thank you again.
UncleWillie
Re: Capacity
The Cap Plate on my 18' Bowrider list 8 people.
There is only seating for 7 available unless someone sits on the Cooler.
I have had 7 on board while Tubing with no issues. 3 Adults, plus 4 kids all under 100# each.
Just because the math comes in at 11 doesn't mean you ever need to take that many.
When all the Seats are full, You're Full!
BobGinCO
Re: Capacity
Mine says 13 people. No WAY am I letting that many people on my boat at one time, unless I'm rescuing the Norwegian Women's Beach Volleyball Team from a boating accident.
Re: Capacity
When rating hull capacity, one of the important considerations is centre-of-gravity. A neighbor has a 18/19 foot Sea Ray that's only rated for 6 ppl / 900 lbs because it has an aft cabin that raises the cockpit considerably. His boat towers over mine, and mine is longer and wider.
I've carried 6 adults and 4 children in my 20' Cuddy without problem as it has a very low centre of gravity, but still has a good freeboard.
mrdancer
Re: Capacity
Correct, a capacity plate is not required for boats over 20'. It is generally assumed that the captain of a larger vessel (>20') has the experience and expertise to properly load and operate their craft. However, a CG inspector can still pull you off the water if they deem your boat unsafe for the conditions and/or its occupants. It shouldn't be an issue if you're using common sense.
H20Rat
Re: Capacity
capacity plates may not be required at all, depending on your state laws.
emilsr
Re: Capacity
To clarify....
USCG requires a capacity plate on monohull boats of less than 20'....however....
For NMMA certification, all vessels less than 26' are required to have a capacity plate. The wording is a little different (says Coast Guard on the smaller boats' plates) but the information and the math used to derive the maximum capacity is the same.
Some states require a capacity plate on boats up to 26'....so check your state laws as well.
oldjeep
Re: Capacity
And just remember that now days most people hit the weight limit before they hit the people limit ;)
emilsr
Re: Capacity
In late 2011 they changed the "assumed average weight" to 185 lbs. I'm still overweight....but not by as much. :D
H20Rat
Re: Capacity
To clarify....
And to further clarify, that only applies to USCG waters, of which most inland lakes are NOT. And NMMA isn't a law enforcement body of any sort, its a voluntary manufacturer organization.
NYBo
Re: Capacity
And to clarify even further, this requirement applies to the manufacturer, not the owner. There is no CG requirement for a capacity plate on any boat. However some states or other jurisdictions may require them.
