Carb Help
fireman4203
I am rebuilding a carb on my 2001 Merc 9.9 - 4 Stroke and need some help. I have read the posts in the FAQ section about carbs and it says to adjust the float but I cannot seem to find any set screws on my carb for adjustment. Could it be that mine is too small?
hkeiner
Re: Carb Help
You adjust the float by bending the metal plate that is part of the float's hinge. There is no screw adjustment.
fireman4203
Re: Carb Help
OK Carb is rebuilt, engine is running. I now have fuel coming out of one of the overflows on the top when I run the engine. Any suggestions?
PERFIND
Re: Carb Help
IF engine is running rough, the float may either be stuck or the float needle valve could also be stuck or otherwise improperly installed. Check for binding/sticking.
fireman4203
Re: Carb Help
The engine is running fine other than the fact that gas is pouring out of the top of the carb..... I have tried hooking a hose up to the carb and blowing into is as suggested in the FAQ. With the float open I can blow freely. When I flip it upside down the float closes. I meet resistance but can still move air through. Hope this helps.
