Carb ID number
Mac_55
hey everyone , picked up a set of carbs this weekend dont know size of motor they came off of but i do have the id #'s if someone could help me out , there twin carbs
top carb TC-108B-921
bot carb TC-109B-921
both have 699061-1
im thinking there force , they came with black intake manifolds
if anyone can help with year or HP size
TwoFish
Re: Carb ID number
Manufacturer is Tillotson. Go to their website. Look on the support section. They have a list of all the carburetors they make and reference the motors they were fitted to.
Mac_55
Re: Carb ID number
carb2.jpgcarb.jpgTillotson website gave me nothing
which sucks because i have three sets of carbs that i would have liked to figure out what they go to for further builds
WB9A
WB8B 333061-1
WB26B 498061-1
the set i just picked up also have a number stamped on the intakes 440167
Frank Acampora
Re: Carb ID number
The TC carbs will fit either the 120 or 125 horsepower Force engines. (or Chrysler 4 cylinder engines.)
WB26B Is usually an 85 horsepower carb, Chrysler or Force. Off the top of my head, WB8 and WB9 are probably for three cylinder engines. If you remove a bowl and look for the venturi size stamped in the casting under the float, if the size is 1 3/16 they are for smaller 3 cylinder engines. If they are 1 5/16 they would have been used on 85-90 horsepower engines.
Mac_55
Re: Carb ID number
right on ill check that out tomorrow, the WB26B came off an 85 chrysler or so i was told buy the guy, but the block numbers and everything else matched my 70 chrysler so i was worried the guy had just swapped cowls, but its good to know that there are honest people still out there .
so 70hp carbs are smaller then 85 and 90hp ?
Frank Acampora
Re: Carb ID number
For Chrysler, yes. But don't think that swapping carbs will give you 85 ponies. The 70 has much smaller exhaust ports and that is pretty much what sets the power output.
jerryjerry05
Re: Carb ID number
Those carbs are for a 125 begining 80's to 90.
What are you trying to do with them?
Mac_55
Re: Carb ID number
a friend of mine is running a 105 on a hydrostream and he was looking for 135 carbs but i figure ill clean the 125's and let him use them
Frank Acampora
Re: Carb ID number
Here are a couple of photos of my 105 with the big TC carb conversion. They really don't do much extra but psychologically, they just look better on that big four cylinder engine. It now puts out an honest 90 horsepower. Your friend can install them but tell him not to expect miracles and certainly not to expect 135 ponies.
Question about the 90 HP? Chrysler rated the 105 at the powerhead. When ratings became standard in the early 1980s, Chrysler simply re-rated the 105 as 90 horsepower which it always delivered to the prop.
BTW: It tops out at 45 GPS on this 15 foot Glastron V153
Mac_55
Re: Carb ID number
nice, you did a good job on the paint and the emblems,
i just pulled apart all three carbs and all are 1-3/16 with different main jets
70hp has .062
85hp .064
hopefully 90HP .066
any reason for this ???
my 70hp on a 14" comet with 2 blade brass runs 40mph but after that it gets hairy
Frank Acampora
Re: Carb ID number
This little gem of an engine does 45 on this 14 foot flat bottom. It took 30 horsepower more to reach 55 then another 30 to reach 60.
Jet size is not only a function of higher horsepower--usually the jet size increases with higher horsepower engines-- but it is also related to carb design. Although the basic casting is the same all the smaller WB carbs are vented differently to maintain constant fuel/air ratio.
Same thing with TC carbs--they look the same but there are subtle differences.
Practically speaking, I have never re-jetted a carb or had any running trouble when switching from one horsepower to another. For example: The 105 originally came with two 1 5/16 venturi WB carbs. I simply switched manifolds and bolted on the much larger TC carbs with no modifications.
Oh, OK! I did rejet my modified 140 from .094 to .105 main jets. No increase in performance and less fuel mileage.
Mac_55
Re: Carb ID number
alright ill just run my little 70 till i get a bigger boat just figured if the carbs were all the same size and the jets were larger i could get away with a little more fun on the comet
Mac_55
Re: Carb ID number
so you guy think i should run the carbs with the larger mains or do you think it will even make a difference since they are all 1 3/16
