carb info
Ski1491
Got a 21" Four Winns 214 project boat I'm working on and it had no outdrive and a blown 5.0 so I' m putting a 5.7 in it. I'm using a truck engine with the marine parts from the 5.0 as many of you have suggested, however I need a carb. The old engine had none so I have nothing to rebuild or a reference point. Any suggestions on aftermarket carb's you are happy with. Like to hear your suggestions.
Also I will be putting a Volvo SX outdrive on as it had before, single or dual prop? Is there a big difference and is it worth all the extra money?
Thanks in advance for the help and advice
Ski
Re: carb info
Ayuh,... 2bbl. or 4bbl. Carb,..??
Duo-props are Most Definitely worth the extra Cash...
Ski1491
Re: carb info
Guess I'm looking for a suggestions regarding 2 bl and 4 bl since I'm starting from scratch.
Re: carb info
Ayuh,... You said you were using the parts from the old motor, which is Why I asked...
What Intake manifold do you have, or Do you have 1,..??
What Vintage is this barge,..??
What Vintage is the replacement motor,..??
Tell Us something about what you've Got,...
This GUESSING,... Sucks....
zbnutcase
Re: carb info
The #1409 Edelbrock marine carb works well if you have a 4BBl manifold.
Ski1491
Re: carb info
Sorry, the manifold is for a 2bl carb. Boat is a 1999 Four Winns 214. Engine is out of a 1999 Chev 1500 (EFI)
Re: carb info
Ayuh,... Ok,... Do you boat in Salt, or Freshwater,..??
Standard raw water cooling,..??
If you want the power of a 4bbl. carb, go with the Edlebrock like ZB says...
You'll need a Vortec manifold,....
Aluminum will work if you boat in Freshwater, or if you have a Closed cooling system...
Otherwise, ya need a cast Iron manifold...
Ski1491
Re: carb info
I'm in salt water here in the Gulf (may be boating in crude oil!). Was tring to keep expenses down so I was going to use the old intake. Any recommendations for aftermarket 2bl marine carbs? Thanks for your patience
Re: carb info
Ayuh,... Best I can figure, you want a Sierra 18-7621....
