Re: carb kit for two barrel holley ??? maclin or don please
It is a 2300 series, although many variations.
If you mean the whole carb kit then you can search with the r82028-1 number online at Summit or Jegs or Holley and find the kit#.
If you mean the base gasket then Holley or Jegs or Summit Racing should have that also, should be able to look that up by category starting with gaskets, then carb base gaskets, then 2bbl, then Holley brand, etc.
Could also look at a parts house, they usually have stuff like that on a wall somewhere.
Do you have the original one to compare to? Also note the intake manifold configuration, whether or not it is 2 holes, one for each barrel or an open oval.
Do not use silicone. Base gasket to manifold and Carb to base gasket should be dry.
