Re: Carb kit
I went home to check my notes and hey, we have the same list # carb. This makes it easier. The Holley kit # is 37-1542. This is called their "fast kit" or something. Its 19.95 at summitracing.com. It has everthing you need except for the secondary diaphram. It goes in the housing off to the side of the carb on the starboard side, the sqarish one with four screws. If the carb has been sitting long, it is suspect. You can take the lid off and make sure it is not torn or chrunchy. The lid will be a PITA to get back on. You will get used to it.<br />Last thing. My carb is wierd. The front fuel bowl is sealed, marine style (no external adjusting screw for float level) while the rear one is common Holley style with the large hex nut under a large slotted screw. My OMC parts book shows my Carb with normal float screws front and rear, while a current Holley Marine 600 has marine style float bowls (no external adjustment) front and rear! Exciting stuff. If
your carb has marine float bowls, you also need needle and seat part # 6-511 they are 10 bucks and have a viton tip for better sealing. The regular needles are in the kit I mentioned earlier. The rear fuel bowl comes off just like the front one, it is probably glued on by the old gasket. Just beat with a rawhide mallet a little bit it will pop off. Get a gallon of CHEM-TOOL carb cleaner. disassemble. Soak offending parts in this stuff, for a while but as little as possible as it chews through the carb plating after a while. Scrape off the old, horrible gaskets with a plastic scraper or sharpened popsicle stick. Metal scrapers peel off the little sealing beads on the parts and fuel leaks are a serious bummer
Once all parts are clean, take a straight edge and lay it across the main body where the fuel bowls sit and the base. Any banana-shaped main bodies will cause all sorts of wierd running problems. You can get these planed at a machine shop, if necessary, If you find a bunch of goo on the front metering block, soak that baby. Get a syringe and gently shoot carb cleaner into all the little holes and their are some in the main body, too. If they are all not clear, it will run wierd. When you reassemble, be easy on the torque. The carb screws don't hold the whole boat together. The sound of all 4 holes feeding your '02 the first time wiil be great.<br />Jon
