carb leaking fuel when primed 48 hp johnson
sambrigman
i have replaced the float, the needle and the seat. when i pump it up fuel pours out. I have no idea how this happens when i know the float, needle and seat are good, with the carb off i can blow and float works as it should. any ideas suggestions greatly appreciated.
Well----Time to revisit carburetor work.----There is something wrong with float and or float valve.
flashback
Even with all new parts the float still needs to be set correctly .
tphoyt
What kind of kit did you use. Some of the cheap knockoffs don’t always come with a matching seat and needle. Seen it more than a few times.
