Carb leaks!!
rsg1509
I have a 1986, 115hp Mercury. It will not stay idling and when I took the cover off I noticed that the bottom carb leaks gas out. Does anyone know what might be causing this.
KCLOST
Re: Carb leaks!!
It sounds like you need to do a rebuild on the carbs...<br /><br />Get a manual and follow the directions, it's not that difficult if you have all the proper info in front of you... New needles and floats, may be in order... They have a rebuild kit that will provide you with everything you need.
