- Mar 8, 2009
- 43,701
Re: carb not picking up fuel
Many times it looks like a regular 90 degree brass fitting. You almost have to take it apart to see. Try this before you buy another pump. Take the pump off and put a hose in the inlet and place the hose in a gass can. Pump the fuel pump lever and see if gass is pumped, try to put the pump above the gas can at least 2 if not 3 feet. If it can lift 3 feet and supply good flow it may not be the pump
I have not tried another tank i do not have one to try.I dont think it has a antisiphon valve? It only has a hose that goes to the tank witch goes to a fitting with a tube on the end.(which picks up the gas) And the hose goes to the separator and it can travel freely to the separator.
