Re: carb problem
Most likely your float level. You need to pull the carb or carbs, pull the bowl/bowls, flip the carb/carbs upside down. Then check to see if the floats are level with the bottom of the carb bowl mounting surface. This "should" fix leaking, but if the seats are worn or the needles are gummed up, it will likely keep leaking. Hope that helps
