BK is correct. You can't tell how clean the carbs are unless you drop the bowls off the carbs and inspect the passages in the carb body. Dried/old fuel tends to settle at the bottom of the bowls and can clog/restrict the high speeds jets. You can't see any potential problems by looking through the carb throats.
