Hi All,
I'm cleaning & rebuilding carbs (my first time ever rebuild) on a 2001, 90 Hp, V-4, two stroke Johnson and have a question.
The (OEM) needle valve rebuild kit comes with a nylon, valve seat gasket, and the original valve seat has none. Should I install the gasket or not? It seems to affect the way the float drops (less movement with the gasket on).
Also, the new needle valve is all metal, and the original has what seems to be a rubber tip. Has OMC/Bombardier changed the needle valve design on these models?
Thank you so much for any help!
JP
JP
