JJB
- Dec 28, 2006
- 274
I am rebuilding my carbs and in the manual it tells you to adj the floats from 11/16 to 1 1/8 inch to the mating surface when the carb is held in a up right position . what is the best mesurement to use and what is the effect in the changes of that adj . ? The invert mesurment has only one adj . that is 1/32 parallel to the bowl surface . I am in florida so I am at sea level and its a 2000 175 Johnson Thanks for the input !
Thanks tashadaddy for the screwdriver idea work great those jets were really dirty !
