Carbs on a '79 Evinrude
Captain Caveman
My '79 Evinrude 35hp shop manual says nothing about spraying fogging solution into the carburetor throat while running. I've done this with all of my other old motors (this is the first time that I've winterized this motor). I also couldn't find the carburetor throat.
Do I not need to do this?
F_R
Re: Carbs on a '79 Evinrude
It's always a good idea to fog for storage, even though hoards of people ignore it. Anyway, your motor has an air silencer on the front of the carburetor. I think it has a plug that you can remove to get the spray nozzle in without removing the silencer.
Captain Caveman
I guess I'll have to read the manual and look around for that plug if it exists. In any case, I already pulled out the plugs and fogged the cylinders directly.
Do you need to do both or is performing either one (spraying through the carburetor / spraying through the spark plug opening) good enough?
R.Johnson
Spraying through the carb lubricate's all the moving part's, not just the cylinder walls.
