carburetor options.... mine is toast.
ScottinAZ
Master Chief Petty Officer
carb in question is a small base 2gc, P/N 17059054 off a 1980 Mercruiser 120 4 banger. This is to the best of my knowledge the original carb. Well, the accellerator pump is shot. The checkball at the bottom of the passage is corroded in there but good, cannot remove, and no shot of fuel when pumping the throttle.... needless to say the engine runs like dogcrap coming off idle due to this.
Carb was cleaned and gaskets redone last summer as part of a larger re-commissioning of the engine and drivetrain. I missed this checkball....
The way I see it, the best option is to replace the carb with one that hasnt been exposed to the ravages of time and corrosion. I am having issues finding someplace that has a reman carb that replaces this piece. Mostly what I see are new build carbs, but they are by and large the "larger" base (3 3/4 vs 3 1/4 as I need). Others are a new build Mercarb, but I dont know the base size on a Mercarb....
does anyone here know of a good rebuilder, or the size on a Mercarb that I can use as a near direct replacement for the low grade boat anchor that is on my bench????
kenny nunez
Get some muradic acid and put some in the plunger cylinder. Let it foam then wash it out with water. With a small pin punch tap the ball a few times. Repeat the process a few times and the ball should loosen up and also with a pointed scribe try scraping around the ball.
I have used acid and glass bead blasting almost the same amount of times as carburetor cleaner since water was quite often the cause of the carburetor problem.
brian3127
i bought a new one from summit racing for i think under $350.
ScottinAZ
ended up removing the passage plug on the carb. Completely full of crap (now cleaned out). Check ball popped right out once that crap was removed. Plugged passage with setscrew and loctite. Accel pump now works!!!!
