Re: Carrying extra fuel?
Chris in Va...<br />If the fuel storage device is not USCG approved, it is not only dangerous, it is quite simply... illegal on most all US water ways...<br /><br />Since it is obvious you feel the need for carrying spare fuel, I am going to suggest you not only do it safely, but legally. There are a HOST of manufacturers out there who build standard sized APPROVED tanks, that you SHOULD be able to find a place in your boat for. If not, there are a number of folks, who can construct for you a custom fit tank. In either event, it should be properly vented, with the filler neck placed such that you do not run the risk of spilling fuel internal to the boat, when refueling.<br /><br />Add a USCG approved manual switching valve to allow you to draw fuel from the tank of your choice ($45, at your local NAPA auto parts store) and voila!! You not only have the spare fuel you wanted, you've done it legally, and more importantly SAFELY.<br /><br />I did the same thing, for many of the same reasons you've stated... My whole set up, including all hoses, fittings, valves etc. cost approx. $150 (less than a single tow). It's approx. a 10 gal. unit, that I placed under a rear seat, where there used to be a small locker for storing ski ropes, a spare prop, etc. I had to modify the seat hinge/cover a bit, but it provides an enhanced level of "safety/comfort", that works for me. I added the fuel filler adjacent to the original, and put the switching valve in the engine compartment, so all I have to do is tilt the engine cover a little to reach in,and switch the valve.<br /><br />ALSO... at first I tried to put a tank in the bow, but learned a good lesson of why you should not do that... I'd suggest you try to put the spare tank, as far rearward as is practical, as the farther rear you go, the smoother the ride, and (as I found out)... since fuel has a tendency to want to vaporize at an accelerated rate when it is shaken, it will be much happier near the rear, and give you a WHOLE lot less venting hassles.<br /><br />Good Luck, Obiwan
