Caution, pink floatation/insulation thickness
bananaboater
Ensign
The Owens Corning "1/2 inch" thick pink styrofoam is not 1/2". An asterisk by the number leads you to an explanation that says "nominal." Who'ed a thunk? Or even looked for the asterisk. :eek:
My Jet Starcraft's insulation is sandwiched in between the decking and the hull and between the ribs. I measured the old insulation, 1" thick. Went to HD to buy 1 inch thick, not stocked. So I bought 4 sheets of half inch at $10/sheet, cut them in half to get them into my Rav4, came home and began cutting them for the boat. I always do tests to be sure what I am doing will work and after cutting two sets of flotation I placed them in the boat and tried fitting a scrap piece of 1/4 marine ply over them. It gets pop riveted to the ribs. Seemed too thick so I cut some smaller thinking that the flange of the rib might be making it too high. Not so.
Then I took two stacked pieces of pink and laid them down next to an old white and low and behold it was about 1/4" thicker. That is when I saw the "NOMINAL" asterisk.
It seems that the "half inch" is the only one with that annotation so if you need exactly 1 inch of pink Owens Corning floatation DO NOT buy two sheets of "1/2"" thinking that will work.
So it goes. In the 21st century one would think a company as well established as Owens Corning could set their machines to produce a half inch thick piece of pink insulation and avoid making human beings like myself $40 poorer.:mad:
I guess my shop will be a bit warmer this winter.
Mark42
Re: Caution, pink floatation/insulation thickness
That is odd. The Owens Corning 1.5" I used for making my hard top is 1.5" thick. Wonder why the .5 inch is different?
vegasphotoman
thanks for the post...
yeah seems everythinig is not what it seems or says it is, take 2x4s 2x6 2x10s and such
all 1 1/2 x and inch less on the wide side! STUPID call em 1.5x5s then eh...
atlease most plywood is the size it ways it is thank goodness
same goes for drill bits and sockets.......
cheers
lakelover
A good thing to know. This weekend I'm going to try to buy some sheets of blue styro from my cousin who has been storing them in my basement for a couple years He better give me a good deal or I'll charge him a storage fee:eek:. I'll measure them first though.
redfury
Actually, that tidbit works for me, as I cut my templates for my floor and they fit almost perfectly. Thing is, I'll be using ply with glass over it, so the glass should be close to making it the same thickness.....coincidence? :confused::eek::D
i386
cheers
Dimensional lumber is first rough cut to 2x4, 2x6, 2x10, etc when it's "green". After it's been kiln dried it gets milled down to its final dimension.
Beats me on the foam though.:confused:
lakelover
I wonder if it was only actually 1/2" thick if it would be too susceptible to breakage, so they made it thicker? I dunno, just a thought.
sbklf
If you use it for flotation, you might want to make sure it is gas resistant especially if your tank is under the sole. Gas will dissolve a lot of Styrofoams in an instant.
