I recently had my lower unit worked on and unbeknown to me I think that forgot to add the thrust washer. I ran the boat without the thrust washer for about 45 min total and every time I went to full throttle the motor would cavitate. The prop has now ground into the lower unit housing
[picture of the old lower unit attached]
Also, I noticed that I didn't have a trim anode (there's a giant hole where one should be). Would this add to the cavitation issues?
Tertiary, I think my gimbal bearing is shot. It make a grumbling noise the whole time I'm running. Do I have to undo all of the bellows again or can I just use a slide hammer and an alignment tool through the gimbal housing?
Thanks!
Thanks!
