Faztbullet
- Mar 2, 2008
- 15,934
Factory recommends star (grounding washer) first, then cables and locknut
Upon further digging, I found another article on this subject and it seems the Faztbullet and saltchuckmatt comments are on track with their comments a wet cell battery is necessary and the charging voltage requirements to charge the AGM battery do not match the CDI Electronics rectifier/regulator output across the RPM range.That rect/reg is designed for a wet cell battery and the AGM will not work
