Center console project
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Interesting, do you have any data on how it compares to 3M 5200? I know that is the go to for most boaters.
SHSU
Watermann
View attachment 329292Hey thanks for the reply, Your talking about these circled pcs correct?
Yes those are the braces that these SC boats over 16' really should have. 16'rs just don't seem to have the problem.
Not sure I know what you mean to use the adhesive for, gluing the braces rather than solid riveting?
classiccat
"Captain" + Starmada Splash Of The Year 2020
That SubStructure is Lookin' good!
One thing that I see missing is a sub-deck track for running control cables, wiring and fuel lines. I did a CC conversion on my last boat and used several PVC runs; it was crucial. In your case since the lateral supports are already fastened, you can still feel long lengths of aluminum sheet metal and fabricate a trough by connecting to a longitudinal stringer.
Dave Aluminum
SHSU
It’s cheaper, $13/tube (310ml)
I’ll ask the Weicon Monday and cut and paste they’re answer to why use Weicon vs 5200
I’m not saying it’s better...... I’m not 100% on anything. Ha. Cheers
Dave Aluminum
SHSU
WEICON Flex 310 M Classic adhesive and sealant is strong, overpaintable (wet in wet), sandable, has outstanding aging stability and good resistance to UV rays. It is resistant to freshwater and salt water and is free of silicone, isocyanate, halogens or solvents.
The product has an ISEGA certificate and can be used as an adhesive in food technology. Flex 310 M Classic is an elastic adhesive on an MS polymer basis and is suitable for the bonding of metals, many plastics, ceramic, wood, glass and stone.
WEICON Flex 310 M Classic can be used in metal construction, tank and apparatus engineering, carriage, vehicle and container construction, ventilation and air conditioning systems, in the electrical industry, yacht and boat construction and in all applications where silicones or products containing silicones are not suitable.
Dave Aluminum
Yes I’ll run pvc to hold all my electrical, majority will be within the Center console, but yes running forward and rear will be conduit/pvc,
I can still bend/sneak it in, I’ve tried already. 100% it’s needed.
SHSU
I will have to look at it. Its cheaper then 3M 5200 if you don't include shipping. One site showed it was $12.99 but shipping was $67. Would be interesting to see how it stands up overtime for your project.
SHSU
Dave Aluminum
Finally got the console framed, needs bracing at every corner, 40” tall, 38” long, 25” wide…..can’t wait for more progress, one rivet at a time. Conduit next for running wiring ……cheers
SHSU
Love the supervisor and safety officer!!!
Will be a great boat for memories
SHSU
Watermann
The rebuilding stage is the most fun part of the project and I really enjoyed working with the aluminum framing materials, even more so than wood but far less forgiving.
Looks great and adding the angle AL across the ribs should help stave off rib end cracking. Have you decided what to do for the braces to isolate the spray rail chine?
Dave Aluminum
I’ll be honest, I’m not going to tie upper part of the chine to the lower, this boat hammered Lake Erie for 40 years before it was in my possession, without issues or any signs of stress. I’d rather fix after vs put so many rivets thru close to the water line.. I’ve never seen a split hull, only people telling me it can happen.
Dave Aluminum
If I do anything towards that …I’ll weld in some plates in the area’s larger starcrafts have them riveted in , pains me to drill below the waterline…..
Watermann
Starcraft factory put the braces under the rib ends, welding near the seams will destroy the sealer and possibly cause issues with cracking later on. Yeah there are already 100's of holes filled with rivets below the waterline.
Not sure how many of these cracked out spray rails you want to see but I can assure you it's not a wives tale. Ask @Bondo to tell you his account of this issue.
y4mkWFGzKldL_G5vJE9Wi_a2vqde2yBZ0JYt21piAqKEXKE_LggFyxNOldasrtn6ach9JdeT7366EHBmUSzoP_3obpesoJ4JbJhVCh-PZmxQ0Zm2xvUlNJuynJh4XCaLddT6eXwjr3RA1jLsu7gi5CnyXXm2RDZnCV1Q5DM9v3QpXmkwH_GaxJSnCd31-P3Mz6c
Dave Aluminum
Dang, well if that isn’t motivation I’m not sure what is…. Guess I’ll be drilling more holes. Cheers
DCampbell
wow ! I would hate to see that.
DCampbell
what did you use to clean your hull with ? Im thinking I might use a brass wire cup on a drill or angle grinder
Dave Aluminum
Finally made templates and have now fit all interior wood panels, now to epoxy and oil based paint
Getting all carpeted this weekend ……..
Time and money…. Time flies
