A friend of mine just picked up a used boat with a 5.7 VP in it. He isn't sure when the last time the oil was changed, but he said that it looks like it has been awhile.
He wants to make sure he flushes the maximum amount of contaminants out of the engine before the winter layup. His idea is to remove the existing oil and refill it with a cheap dino oil. Run it on muffs for a while, then drain that oil. And finally, put in synthetic (which is what he plans on using here on out) before storage.
His question to me (and now to you since I wasn't sure) is it worth it to run the clean dino oil through to clean remaining contaminants in the engine? And also, if it is a bad thing to put the dino oil through the engine and then change to synthetic?
Thanks,
Greg
Thanks,
Greg
