Changing Ignition System on 89' 5.7L GM Mercruiser
T/A Hawk
Has anyone changed the the igintion system from a thunderbolt IV to GM HEI and is this possible?
Chris
89' Wellcraft Eclipse 233 5.7L GM, Alpha One
bomar76
Re: Changing Ignition System on 89' 5.7L GM Mercruiser
Why on earth would you want to?
The TB IV is the most reliable, easy to diagnose, and dependable marine ignition system on the market.
There would be NO benefit of going to an HEI setup.
Don S
If you are talking about an automotive HEI system because it's cheaper, forget it. It's not spark protected, and doesn't have the proper advance for a marine engine.
T/A Hawk
That's exactly what I was thinking. Thanks, I guess I'll order parts for my Thunderbolt.
Don S
What exactly is wrong?
wca_tim
if you've a major problem, there are often whole set ups or at least distributer and the associated ignition module for sale used for 100 or less. and to be fank, I'd replace a gm hei ignition with a tbolt iv long before the opposite
