tahoejag
- Jul 4, 2009
- 229
ProMariner Tournament 100 2 bank 10amp 12/24 volt system charger. (2) SRM-29 Interstate Deep cycle bat. Minnkota Terrova 80lb 24 v motor 1 year old. SITUATION - First off, charger checks o.k. bench tested as per ProMariner Service Tech and also batteries check o.k. tested under load (was said to be like new). 2 banks (one on each 12 volt bat that is connected as 24 v system) batteries charge fine and charger does NOT get hot at all (charging cycle takes aprx 10 hours) (note: at this time the batteries are NOT connected to the trolling motor wiring that lead to the bow plug).
When the trolling motor wiring is connected to the batteries (w 50 amp breaker in line), yet the trolling motor itself is unplugged from the bow plug - the charger will get VERY HOT as cannot even hold hand on it. Yet it does go thru the charging cycle and goes into a float mode.
When on the water motor seems to perform ok and drains batteries down as normal. What is not normal is the overheating of the charger once the 24 volt battery system is connected to the motor wiring even though the motor itself is unplugged at the bow while charging. Was recommended just to disconnect the wires that lead to the bow plug from the batteries, but that is not fixing the situation, rather masking it.
I have talked to and took the boat to several shops and they are stumped as to why the charger overheats when the system is connected, and so am I. Could it be the motor itself shorting something out? Any input/suggestions or help is GREATLY appreciated in this matter. Thanks! John.
