Charging Question
pikefisherman
When is it time to recharge a deep cycle battery? I just use it for troling motor and fish graph, not starting.
I have a digital meter to check it with.
jhebert
Ensign
Re: Charging Question
The time to recharge a battery is whenever it isn't fully charged. Battery life is related to battery care. Better care means longer life.
NYBo
Charge it right after you finish using it for the day.
Silvertip
You DO NOT wait for a specific voltage. When done for the day, charge it.
Barnacle_Bill
Yes, you will prolong the battery's life by recharging immediately after every use.
pikefisherman
Thanks all I was told to run it way down or all the way.I won't!!
bruceb58
Running it all the way down is the worst thing you can do. Never discharge it beyond 12.0V which is around 50% discharge
