i have a 1997 javelin with a 200 johnson venom. when i turn the key to the on postion it goes through the 4 light test. the check engine light stays on. It will do this without try'n to start the engine. is the tach bad? i mean the thing works, but that crazy light keeps coming on with the buzzer if i crank the motor. if the tach is bad where do i get one? or is there any thing else i need to check before i bring it to the boat mechanic.
I reached under the dash to see if the conection was loose and the light would come on and go off when i would shake it. now it just stays on.
sorry so long, try'n to tell it all. thanks!
