Checking alignment -- can this be right?!
Liquid_force
Hey...<br />I bought the $100 transom service kit from basic power to do b4 the season.<br /><br />I've gotten the old bearing out and the new one in. Since my alignment tool didn't arrive on time I removed the u-joint shaft from the stern drive to use as a temp alignment tool.<br /><br />What's really confusing me is that it seems the u-joint shaft is too large for the new gimbal bearing! The shaft taper seems to exceed the ID of the bearing just before it reaches the o-rings - which I assume are supposed to ride inside the gimbal bearing. To the naked eye it seems that there's a significant difference in diameter -- 1/16"? Maybe 1/8"? But I'll admit my level of panic could be effecting my approximation.<br /><br />Is it possible the alignment is so far off the u-joint shaft appears too large for the gimbal bearing?<br /><br />I contacted basic power and was told there's no "larger" bearing that could have been mistakenly shipped with my kit -- the same part is used for mercs/omc's/volvo's, and as for the u-joint shaft - the only variance for my drive is length.<br /><br />For now this appears to be a significant problem.<br /><br />Any thoughts?
bruceb58
Re: Checking alignment -- can this be right?!
My advice is wait for your alignment tool. <br /><br />I would not have removed the input shaft/bearing carrier. Make sure you get all the shims/gaskets back on that you took off. They set the gear lash.<br /><br />As far as I know, everyone uses the same bearing so you should be ok there.
Liquid_force
Originally posted by bruceb58:<br /> I would not have removed the input shaft/bearing carrier.
I just took the u-joints apart.
I/O WALDO
Wait 4 the allignment tool to align the new g.bearing with the coupler.
They're pretty much All the Same Size,......
DHPMARINE
If you take off the o-rings will the shaft go in? <br />I have had a couple shafts with rust under the orings that were problems.<br /><br />DHP
bigbrownbuku
Master Chief Petty Officer
its likely your bearing is cocked and the shaft is butting against the splines in the hub. the alignment too will help you "re-align". the shaft diameter is very similar to the hole in the gimbal bearing.
horsefly38425
did u drive gimbal in from the outer or inner race /outter OK inner O no
Liquid_force
Originally posted by DHPMARINE:<br /> If you take off the o-rings will the shaft go in? <br />
Didn't try that, but it's not going far enough for them to be a factor yet. The lip of the GB is still an inch or so from the o-rings.
