Checking fuel pressure
KetchiMan
2004 Merc 5.0L MPI
Looking for some advice on checking my fuel pressure.
Does anybody know what the psi "should" be in my system?
Do I check it at idle? While the boat is under load? Both???
Thanks
Don S
Re: Checking fuel pressure
Going to say this again, need a serial number not year. NOTHING is listed by year, only by Sn.
KetchiMan
Sorry, I should know better.......
Serial # is OWO18920
Fun Times
2004 Merc 5.0L MPI
Thanks
Your looking to stay within the 43 PSI range at both key up & all RPM's.
KetchiMan
So, I just checked the pressure and she's running at 15-16 PSI. Not good. I replaced the LP pump and filter.water separator a few weeks ago.
Also, I took some fuel out of that schrader valve today and looked at it. It had tiny little shiny flicks in it, like little pieces of metal. I put a magnet in it and the flicks are NOT magnetic. Maybe Aluminum?
Is the HP fuel pump made of Aluminum? Are these tiny flecks of shredded fuel pump?
The flecks seem to indicate that there is no filter between the HP pump and the injector rail, so it can't be a clogged filter.
My best idea right now is to replace the HP pump.
Am I missing anything or is this the thing to do?
Thanks
Scorpion8
I would replace the HP pump because you're not getting the boost in pressure needed to run at higher RPMs. I'd also look at adding a fuel filter/strainer in the line before the fuel rail.
And I'd move away from Ketchikan. Way too much rain down there.
KetchiMan
Would a filter after the HP pump cause resistance and restrict the fuel pressure?
Rain?
We only had about 4 inches of drizzle today, and the wind is gently blowing about 25 knots, so I don't really know what anybody would have to complain about..... :)
Scorpion8
Rain?
It may, if your pump is putting out metal shavings. If not, then a simple strainer would suffice after you replace the HP pump.
Lucky you, we had 2" of liquid sunshine all day at 15 mph.
