roscottjr
- Jun 10, 2006
- 330
I tested stators on 2 engines I have. 1 is a 1964 Johnson Meteor 90 hp model V4ML-10R, this stator has 2 sets of 2 leads coming out of it. The other is a 1971 Evinrude Triumph 60hp model 60173 C, this engine has 1 set of 2 leads coming out of it.I just want to make sure I checked the stator correctly. I set my ohm meter at 1000. attached the meter ground to engine ground, attached meter hot to one lead from stator and then to the other lead. Needle did not move at all on meter. I then attached meter ground to one lead on stator and meter hot to other lead on stator and needle on meter moved all the way over. I forgot what the actual reading was. I did this on both of my outboards. If I am correct, does this mean that the stator on both engines is good?<br /><br />Thanks for any info<br />Robert
