Re: chrysler 100hp 1979 thermstat?
Chrysler and Force engines are notoriously difficult to prime on muffs.Unless you have really good pressure it will take a good bit of time for water to start spitting out the rear idle relief vents.
The thermostat is located inside the rectangular "box" at the top of the head. However, before you check it, it would be better to drop the lower unit and check the water pump impeller. If it has not been replaced recently, replace it as a matter of course.
If you go to the Chrysler/Force forum, you can search and find numerous posts on how to replace a water pump impeller.
I suspect that sooner or later, the moderators will move this post to that forum.
