Re: Chrysler 130 hp 1973 outboard backfires at low rpm
Profile??Location?? You might be close to someone who can help.
Unless someone's messed with the timing.That should be ok.
Start with,water in the gas?Do a compression test.
Clean carbs.While they are off check the reeds.
Then rebuild the fuel pump(some of this is just maint) with new diaphram.
The ethanol we burn is melting hoses and delaminating the inside of the hose.
Comp good?Then start with the airscrew on the carb.In till it just bottoms out and then out 1 full turn.
Then in the water,motor warm,in gear.
Turn the screw in till it barks,coughs,stalls and then back out 1/2 turn.
RPM's in gear about 750-800.
Top thread is a post by FrankA Called a linc and sinc.Do that too.J
