Chrysler 4 HP
Holy bottoms
I am now looking for parts I am getting no spark at all and at this point no gas to the carb. I have checked the fuel shut off it clear and clean. I replace the fuel line I am now thinking I need a new electrical but I will plug along. The frustrating thing is that this motor is spotless. and rarely used. any help?
F_R
Re: Chrysler 4 HP
The most common cause of no spark is dirty or corroded breaker points. Have you cleaned them? I don't mean a half-hearted attempt, I mean take them completely apart and individually polish each contact shiny bright. Re-assemble and adjust the gap to .020" at their widest opening. That may be all it needs.
Holy bottoms
Re: Chrysler 4 HP
I got the points out and cleaned them and they glistened no spark I am now going to my local boat shop and get new points new capacitor and see if they can find a new coil. The compression on a single pull was 90 so if I can get it going it should be a great fresh water troller for Kokanee.
3rdMarDiv
Re: Chrysler 4 HP
How are you testing for spark?
Replacing the Fuel pump gaskets and diaphragm has always been one answer to fuel delivery problems...:rolleyes:
Holy bottoms
Re: Chrysler 4 HP
I have currently managed to get the motor to fire but it will not run any more than a kick. ?I am thinking that the carb needed to be cleaned and did that so I will see tomorrow. F_R I want to thank you for your help.
Holy bottoms
Re: Chrysler 4 HP
Thank you for your input I don't know if this little thing has a fuel pump if so where might it be ?
