Chrysler tilt shock absorber
driewal
Hi all,
So last year I bought a 1970 Chrysler sport fury, with a 1978 Chrysler 105 outboard. After tacking her out on the lake a few times for the season, it was time for a restore. New deck, foam, carpet and paint. any ways found out the tilt shock absorber on the port side was froze. Can I just run without it?
RRitt
Re: Chrysler tilt shock absorber
Hi all,
yes but ... the engine may bounce when you use TnT and you'll need to put in a bushing or something to keep the mounting shaft from drifting.
driewal
Thanks RRitt. Thats what i thought just wanted a second opinion. I'm just going to cut the shock ear off to stop the drifting.
RRitt
use a bushing. the shock piston shaft is same as tilt piston shaft. if your tilt piston shaft ever gets bent or rusted then you'll want that part.
driewal
Thanks again, thats great info. I will keep it intact just in case.
