Clamp replacement
ss pirate
How to replace clamp screw and handle on 1990 15hp Johnson ? Screw is broken off inside housing.
FLATHEAD
If that is stuck on that stand You could center punch and drill and use an easy out. Or if your not in love with that 2x4 you could just split or chisel at it a little bit till the motor comes off then you can just put a big vice grip on the round foot and spin it out
