cleaning salt and grease from outdrive?
jonny rotten
Redoing bellows cable ETC. Pulled bell housing. I want to clean it up nice. ( no paint) Is there a product that dissolves dried up salt and grease from all the nooks and crannies? Some sort of spray can solvent?
Side question: should I remove the shift shaft/arm in the bell housing and clean and regrease? If so how does it come off/on,,All I see is a set screw on the arm with the roller...alpha one gen 1
JASinIL2006
Water for salt buildup. Vinegar or CLR for lime scale. Acetone for grease residue.
muc
"Retired" Association of Marine Technicians...
Remove the set screw completely. I’ve never removed it just to grease, but there is a redesigned bushing/seal that can be installed to remove some of the play.
