Closer Look at Bell Housing and Shift Cable
CaptainDucky
Re: Closer Look at Bell Housing and Shift Cable
What tick mark does the reverse lock out need to be on?
Also, the boat runs great on muffs. It goes into forward and reverse and neutral and purrs like a kitten again. Yeah!
Problem is now that I cannot get the outdrive to trim up in neutral. It works well in forward and then trims in great in gears forward, reverse and neutral. Why would I not have a trim up in neutral after everything I've done and now this.
Thanks for all your help.
DD
Bt Doctur
1 ,you have the new style cable, DO NOT CUT IT. it comes the correct length.That applied to the old style cable and support tube where you had to cut it to size and install a support tube.If you did cut it, you need a new cable.
CaptainDucky
Ok..so the boat is running great....as I said above.
However, noone said anything about the trimming up in neutral that does not take place. Any ideas?
DD
